bitcomet is blocked
lately at my campus they are upgrading the server.after that upgrade,my bit comet cant download file from the internet already,the download speed always =0kb/s even that hv many seeds.
but bitcomet can still download from the intranet(inside the campus) with a very high speed by LAN conection.before this they r not using DHCP server,and that time no problem to download,just the speed is slower.but now cant download at all!
so,any suggestion how to by pass the DHCP server?please help me…
There is no way at all to bypass DHCP. But it also will not, of itself, present a problem to bittorrent clients, since most of us connect via DHCP. Your problem is elsewhere.
Try using a proxy connection for tracker communication. Also, set the encryption to full or always.
is there any tutorial on proxy setting?
Not really, its pretty simple and straight forward to add a proxy to BC 0.70 and set it for tracker communication.
You just have to use a search engine and find a proxy you can use. There are a few sites with proxy lists.
