Hello,
I have not found the right section for my post so I’m just going to post it here and i hope that istead of deleting my post you will help me guys.
I have 11 torrents downloads in my BitComet program. Every single torrent is downloaded and are set on seeding mode, but it is not seeding for some reason. I have tired to wait more time but it seems like in 12 hours it wasn’t seeding anything at all.
5 Months ago i was using Utorrent and it was seeding perfectly, Also i had BitComet 2 years ago it was fine as well, but now when i have downloaded BitComet and torrents (movies) it did not seed at all.
Maybe you will be able to sort this problem with this post I’m sending my “Statistics” of BitComet where most of information could be found.
Thank you.
STATISTICS
______________________________|
Up Time: 13:01:53
Overall Tasks: Total: 11 / Running: 10
TCP Connections: Established: 7 [MAX:Unlimited] / Half-Open: 52 [MAX:200]
LAN IP: 192.168.2.4
WAN IP: 81.178.211.186
Listen Port of TCP: 10990 (Blocked by Firewall/Router)
Listen Port of UDP: 10990 (Opened in Firewall/Router)
Windows Firewall: Added [TCP opened, UDP opened]
UPnP NAT port mapping: Failed [uPNP device not found!]
Disk Boost Service: Running
Overall Download Rate: 0 kB/s [MAX:1000] Max Connection Limits: 50 per task
Overall Upload Rate: 0 kB/s [MAX:110] LT Seeding: 0 kB/s [MAX:104] All BT Upload Slots: 0
Memory Usage: Working Set: 31.29 MB, Commit Size: 52.26 MB
Free Memory: Phys: 2.12 GB (Min to keep: 50 MB), Pagefile: 5.63 GB, Virtual: 8,191 GB
Disk Cache Size: 5 MB (Min: 6 MB, Max: 50 MB)
Disk Read Statistics: Request: 7495 (freq: 0.0/s), Actual Disk Read: 437 (freq: 0.0/s), Hit Ratio: 94.1%
Disk Write Statistics: Request: 0 (freq: 0.0/s), Actual Disk Write: 0 (freq: 0.0/s), Hit Ratio: 0.0%
Total Downloaded: 22.05 GB (this session: 29.56 MB)
Total Uploaded: 384.58 MB (this session: 149.41 MB)
