I never had a problem using Bitcomet before, but after upgrading to Windows 10, I get “There was a problem sending the command to the program.” whenever I try to download a torrent. This happens on multiple torrent sites.
Bitcomet version: 1.41
Browser used: Mozilla Firefox 47
OS: Windows 10
This error happens mostly because Firefox sends the magnet link or the bittorrent URI with wrong parameters to BitComet.
Follow these steps, and tell us if your problem has been fixed.
Close Firefox
Uninstall BitComet
Reinstall BitComet
Open BitComet and set this up:
***Tools > Options > Integration > ***Always become the default torrent client on startup
*****Tools > Options > Integration > *****Check Now (right next to “Always become the default torrent client on startup”)
Apply the new settings
Open Firefox and set this up:
***Options > Applications > bittorrent URI > ***Use BitComet - a BitTorrent Client
***Options > Applications > magnet > ***Use BitComet - a BitTorrent Client
- Test it, and tell us the results
in my region no torrent is working not at all.Help us.
region Southasia
country Ndpal
