I seem to be having a problem with my passport panel. It may not be a huge issue but I wasn’t sure if this would affect my download/uploads at all.
As you can see, the page won’t load and it says that it is probably because I don’t have a specific file I need. When I click on the option that says “Search online for the download” nothing happens. Also, down at the bottom it shows that I am logged in so I’m not sure if I am showing up as logged in and whether or not it was that big a deal.
I am using version 1.15 on windows xp. I have a cable modem and a linksys router. Port is forwarded and I have a static ip address.
Thanks for the help in advance ![]()
