BitComet Passport
I have recently signed up for BitComet and Downloaded the software. everything was succesfull except when in BitComet, it wont let me sign into my Passport…any input about this Problem would be nice. Much appreciation.
Nobody can help you much without at least some idea of what the problem was.
Elaborate.
Elaborate.
easy it dont connect, mine has the same issue :frowning:
Elaborate= Unable to sign in CometPassport at this time. You can still download, but your rank and score points will not be collected.
unless someone has a way to get more info about this out of bitcomet, its the best i can provide
PS, it was connecting fine until yesterday when i updated from v1.16
BC Version = 1.17
ADSL connection 10mb down 756kb up, verified at speedtest.net
All ports set correct in router and double checked
It sounds to me like you’re being told that the server has gone down – that “at this time” bit.
If you’re posting here to complain about that, we’re not Passport and they don’t read this forum, so your complaints won’t reach anyone who could provide any information or do anything about it.
Hi Kluelos,
Thanks for your reply, nope im not complaining lol, more i am looking for help :wink:
24 hours later its still not connecting however if i use an incorrect password it replys “username and password dont match” but with the correct pass it sits at the signing in window for 3 or 4 mins
Where is the best place to head to for help in this issue?
Cheers
SCM
I feel like asking for help at Passport has been pretty futile, but you can try there and at Tocomet.
They have a new site, CometID.com which may offer more consistent help and current information. We’re also not them and vice-versa, but give it a try.
Awesome, thanks heaps. I will have a surf through them sites and see what I can find :wink:
Please let me know what you find as I’m having the same issues.
Hello, our server was down the last weekend when we had no one at office. But it was OK from Monday. Could you please try again, we tested and all accounts work fine here.
Tired of the run-around but thanks anyway.
I’m having the same problem so I’m guessing they are still having server issues since they moved server? I’m downloading and not earning any points :frowning:
Edit: Funnily enough the problem has now fixed itself.
