bitcomet restart failure
when i restart my pc the task are not there anymore and the files are on the pc but if i reload the tasks it continues from where it stopped! i have tried to uninstall and reinstall but whitout succes. i am using windows 7. help!
Hi!
Are you using an administrator account? BitComet may not have the permission to modify the “Downloads.xml” file located in BitComet’s root install folder. go to where you installed BitComet and right-click the “Downloads.xml” file, select proprieties, click on the “Security” tab, click your user name, click “Edit…”, check the “Full control” box and click OK (do this for as many user accounts as you like).
You may have to reboot to apply changes.
This may also be caused by you inappropriately closing BitComet (from the task manager, hitting the reboot button, crash&reboot etc,) you should close bitcomet by it’s “Exit” button before shutting down your computer.
To avoid losing important tasks go to the “File” menu in bitcomet and select “Import and export” to create/load backups.
When you reload a task make sure you use the exact same torrent file and set it to download to the exact same folder. Also do a manual hash check before starting the task.
Cheers!
Also make sure that you’ve chosen to auto-resume tasks at BitComet startup, in the program options. This is not enabled by default, IMSMR, so you do need to turn it on.
This, kind of belongs to the BitComet General Discussion section.
