Bitcomet shutting down internet connection
I just changed my isp and every time i run bitcomet my internet stops working.i did open all the ports,but nothing.i have adsl 50MB download and 4MB up.i tried with the older version and did the same thing for the 1.23.any info will be very much appreciated.
Actually, any info from YOUR side on your setup will be much appreciated.
Try reading the “Read This Before Posting” link on top of this page.
i just updated to 1.23 version,had the same problem on a older vers.like i said i have adsl and im behind a router(Netgear cg3100d).opening ports doest change anything both in firewall and in router.the antivirus is not32 and running on windows 7.it worked fine till i changed the isp/new router.did lowered the up. speed,but with no luck.if i missed anything pls let me know.
What do you mean by “your Internet stops working”?
Does BitComet still download/show any upload/download speeds?
Does it still display connected peers?
Does your Internet connection still work at all? (I.e. can you still ping your router, your ISP and any other site ?)
Yes i can still download with moderate speed,did watch if i can upload but nothing.it does display peers and has a hard time logging the trackers.when i said my net stops,i was referring to surfing.doest work on any of them like mozila,chrome etc..my internet doest drop,but it cant load/display any web page.i have tried utorrent and it works with that program.tnks again for your time
This sounds exactly like what would happen if you didn’t properly set your global maximum upload speed. What did you set it to?
Better yet, tell us what is your **tested **UPLOAD speed as well.
http://www.speedtest.net/result/1026076162.png
the upload speed is 2.7MB.did test from 14kb to 200kb and it doest change nothing
Correction, your upload speed is 2.71Mb not 2.71MB.
You still failed to answer kluelos’s question. What did you set your upload limit to, in BitComet?
I think i answered that question.you can set the limit only in bitcomet.i tried first with a 150 kb/sec as limit in bitcomet. didn’t do any progress saw i set again the upload limit to 14kb/sec.from what i know i should have the upload limited to around 350kb/sec.the change to the upload limit is not the problem.sry if i forgot the caps on when i write the b
Try disabling DHT and LT-Seeding to see if that changes anything.
