Using Bitcomet v1.13
Wireless Broadband Internet, using HUAWEI Mobile Connect 3G USB Flash Modem (advertised to provide upto 3.1Mbps)
Port Forwarding Yes, both DHT and WAN are green and port(s) open.
Windows XP SP3, with built-in Windows Firewall configured to allow Bitcomet.
Antivirus is Avira AntiVir Personal v9.0
Speed Results from Speedtest.net:
Download - 0.35Mb/s
Upload - 0.02Mb/s
Ping - 313ms
Bitcomet Settings:
Enabled NAT/Firewall config in ICS/ICF
Enabled UPnP port mapping
Global Max D/L and U/L rates at 1500kB/s each
Max concurrent D/L tasks 10
Enabled DHT network; Enable Anti-Leech at Auto
Max. and Min. U/L rate unlimited
Long-time seeding enabled
Advanced Options:
network.max_connecting_connections 300 (max. simultaneous half-open TCP connections)
network.max_connections 150 (global max. connections)
MY PROBLEM:
I have been using Bitcomet for downloading torrent files for 3 yrs now and it had never before caused this problem but now whenever I start a file download on the client, everything else using internet becomes dead: browser, messenger, all other Windows programs using internet.
The problem has started since I switched to this Wireless internet connection (described above). Before that I was using a university broadband internet from LAN cable, and even though at that time my ports were not open (DHT light was grey and NAT light was yellow) and I used to get crappy speeds of max. 1-2 kBps, the browsing would still work fine alongwith torrent downloads.
Now since switching to this wireless internet, when a download starts on bitcomet, internet activity on IE/Firefox/Messenger/all programs svirtually comes to a halt. D/L speeds I get now on Bitcomet, range between 0-50 kBps, although I’m not entirely satisfied with that either.
I have tried the following: changing bittorrent client; switching off my firewall; changing listen port; disabling NAT/Firewall config and DHT; changing Advanced options of bitcomet as well as other options…but nothing seems to work, internet is just dead when bitcomet’s active. Contacting ISP was of no help either, they had no clue of what I was talking about.
Please, Help will be very much appreciated; My download speed is already not too fast and having to stop downloading everytime I need to browse for something is annoying and causes them to take days to complete.
thanks
