BitComet SVCHOST
Hi,
Just like to know if anyone is having the same problem with svchost.exe using a lot of memory when BitComet is running for a day or two?
Nope… but then, you also don’t know anything about my set-up, right (ehem, ehem)?? :wink:
Please read here:slight_smile:
Sorry about that :slight_smile: . I have bitcomet 1.22 running on Windows 7 Ultimate x64.
PC Spec:
Core2Quad Q6600
4 GB DDR 2 800 Memory
The mere use of memory is, after all, not a problem per se. That’s what it’s for. And if a downloading program like BitComet can buffer its downloads into memory, that cuts down on disk writes, which is goodness. Are you encountering some specific problem?
It seems that my AntiVirus was the issue here. Install a new AntiVirus and all is well now. When the memory usage went up my machine would also start playing movies at a very choppy speed. Thanks for everything :slight_smile:
