bitcomet v.70
everytime i run bitcomet or any other network for that matter my computer restarts it happens on both bitcomet and limewire.
computer specs
amd x2 4200+
seagate 300gb 7200 rpm hd
EVGA 7900gt w/ latest drivers
sony dvd combo drive
abit kn9 sli mobo
audigy zs 2
550 watt psu
windows xp pro
sbc AT&T isp (3mb/s dl 512 kb/s ul) speedstream 4100 modem w/ linksys WRT54GS router
there is a new update for my bios, i will try that after just wanted to hear your guys suggestions. it started yesterday it was perfectly fine and i was downloading in limewire and my system just rebooted out of nowhere. my first reaction was overheating but the cpu and gpu are running at 48/c case temp is averaging 80/f.
second i tried with no antivirus/firewall/spyware doctor and then tried bitcomet and the system still rebooted. when it reboots there is a windows error that comes out saying that it recovered from an error, send error report and dont send error report and i click dont send and the system is fine until i start bitcomet or limewire again.
any suggestions are greatly appreciated i have been trying to fix it since yesterday thx in advance guys!
If you’re using SBC/AT&T DSL did you tell the Linksys router that you’re using a PPPoE connection?
it is set to automatic configuration DHCP
still reboots after i flashed the bios
virus, trojan?!?! scan you system with more than 5 virus, spyware and trojan scanners.
