Sam704
August 8, 2011, 12:38am
1
Version 1.28 64 Bit
ADSL internet connection
Roouter, Cicso
Windows Vista
my bitcomet.exe file seem to dissappear for the V1.28 64bit. So I uninstalled the program and then reinstalled it.
I now have the Comet.exe file but it will not work.
I have a 64 bit computer, so I presume that I should use the 64 bit Version.
What do you suggest.
Besides a 64bit processor in your computer, you also need a 64bit windows version.
If you go to “Control Panel>System”, one of the specs will say something like “system type: 64bit operating system”
You can also get there by “right click” on “computer” and select “properties”.
Another way to tell is a 64bit windows version will have two program files folders on your C:\ drive.
c:\program files(x86)
c:\program files
The 32bit version will only have one.
Use of the 64-bit version is optional, if you’re running 64-bit Windows. The installation can be tricky though, going from 32-bit to 64-bit and vice-versa. You must be careful with this and aware of what you are doing.
