when will there be a bitcomet for 64bit operating systems?
well infact when will bit commet work on vista 5384?
the laterst version instals fine, but it doesnt like opening torent files and wont download anything ![]()
thanks
Colin
thanks
Colin
I would not expect anything at this stage that bit comet will make their software compatiable to vista for the simple fact that vista has not been release to the mass public. I would hope that the guys at bit comet will sort out some problems that we are having with the current software.
Yes, there are lots of work to do. We will consider your suggestion.
