BitCometBeta 20060727 Released
BitCometBeta 20060727 can be found at this page:
http://www.bitcomet.com/doc/download-beta.htm
BitCometBeta ChangeLog
20060727
Fix the bug that only few peers is connected
20060724
Fix the memory management bug that may cause memory leak
Fix the bug that the files selection download does not work
20060723
Fix a compile bug that may cause crash
20060722
Add option to auto stop after task finished
Fix UDP Tracker can not be connected
Fix HTTP Tracker redirect do not work
Beta version can only run on Windows 2000/XP
20060719
Add preview
Improve upload strategy.
Install to BitComet directory, can work with release version.
20060716
Fix the crash when click OK in the Setting Dialog.
20060713
Rewrite core code. Some functions are disabled temporarily.
20060727
20060724
20060723
20060722
20060719
Add preview
20060716
20060713
thumperofharley
I’m having out of memory pop up can this be fixed and how please
running XP Home sp2
I don’t now what you guys did with bitcomet but im geting 100KB/s! :slight_smile: and before I was geting 20kb/s?
