BitCometBeta 20060826 Released
BitCometBeta can be found at this page:
http://www.bitcomet.com/doc/download-beta.htm
BitCometBeta ChangeLog
20060826
Add Open BCTP link dialog
Add Task Link page in task properties dialog
Add Half-Open TCPIP connection limitatiom modafication for Windows XP SP2, in Preferences dialog
20060824
Improved BitComet Passport transfer protocol
20060822
20060816
Fix some crash problem in BT download
20060813
Add download speed limit
Fix some crash problem in FTP download
Fix some crash problem in HTTP download
20060811
Remove Pause button
20060809
20060808
Add HTTP download function with multi connections for each file
Task only can be set catlog after download finish
Fix the bug that private tag in torrent file does not work
20060806
Add passport info view in main window
Improve crash report
20060802
Improve the upload strategy
Fix the bug that HTTP protocol processing may cause crash
May fix the "Out of memory" error
20060731
Fix the bug that the file progress can not update
Fix the bug that the connection limit per task do not work
Crash Report can capture "Out of memory" error
20060727
Fix the bug that only few peers is connected
20060724
Fix the memory management bug that may cause memory leak
Fix the bug that the files selection download does not work
20060723
Fix a compile bug that may cause crash
20060722
Add option to auto stop after task finished
Fix UDP Tracker can not be connected
Fix HTTP Tracker redirect do not work
Beta version can only run on Windows 2000/XP
20060719
Add preview
Improve upload strategy.
Install to BitComet directory, can work with release version.
20060716
Fix the crash when click OK in the Setting Dialog.
20060713
Rewrite core code. Some functions are disabled temporarily.
hmm this version is nervous for me when i click left button mouse to file when not download or download allrady bittorent lauch browser :huh:.dht is not loginned in…but DHT connected node: 218.this version have unstable download speed very…low
20060826
What specifically is the change? Is it the TcpNumConnections registry entry described among other places:
http://forums.bitcomet.com/index.php?showtopic=984
http://flum.se/articles/article.asp?id=14
That will not change the maximum *rate *(number per second) of half-open tcpip traffic imposed by XP SP2 tcpip.sys, which is usually the cause for the EventID 4226 in the XP system log. The only way I know of to change the *rate *of outbound half-open tcpip traffic is to edit tcpip.sys with a hex editor. (tcpip.sys is a system managed, or protected, file and it will automatically be changed back if you try to modify it unless windows file protection is turned off.)
There’s a big difference between maximum *number *and maximum rate, and unless people manually edit tcpip.sys, which I do not recommend, I think this change may mislead people into believing the problem imposed by XP SP2 has been solved, when it has not.
That’s just me.
Wow! You are actually modifying the system file.
You are very bold. I’m not sure your courage is warranted, but that’s an appropriate use issue. One school of thought would be it’s ok if you can get away with it. Another might object to the wanton carelessness this method is likely to cause by unknowing users. I find it questionable and I’m definately not going to use that method. You’ll have to deal with it–not only support, but also the effect this has on the character and nature of BitComet. Overriding Windows File Protection to modify system files is serious business, and some people may be hurt and unhappy.
I would suggest at least disabling that method until the user has been warned that what they are doing could seriously affect their system stability and accepts responsibility. Otherwise, you’re assuming way too much competence on the part of the user.
The risk is that Microsoft may update tcpip.sys, like they did somewhere around June 22, 2006 in a regular windows update that most people have configured to run automatically, and following that a user unknowingly runs the BitComet tcpip.sys modification method to edit a new tcpip.sys based on offset values from the old tcpip.sys, networking could be lost and most people would lose alot of time and/or money fixing things.
Good luck!
you are right. We need to think this issue more carefully. Thanks.
