BitCometBeta can be found at this page:
http://www.bitcomet.com/doc/download-beta.htm
BitCometBeta ChangeLog
20060831
Enable seekbar working with Windows Media Player control
20060830
Add UI language edit dialog
20060829
Fix some crash problem in BT download
Fix some crash problem in video file preview
20060826
Add Open BCTP link dialog
Add Task Link page in task properties dialog
Add Half-Open TCPIP connection limitatiom modafication for Windows XP SP2, in Preferences dialog
20060824
Improved BitComet Passport transfer protocol
20060822
20060816
20060813
Add download speed limit
Fix some crash problem in FTP download
Fix some crash problem in HTTP download
20060811
Remove Pause button
20060809
20060808
Add HTTP download function with multi connections for each file
Task only can be set catlog after download finish
Fix the bug that private tag in torrent file does not work
20060806
Add passport info view in main window
Improve crash report
20060802
Improve the upload strategy
Fix the bug that HTTP protocol processing may cause crash
May fix the "Out of memory" error
20060731
Fix the bug that the file progress can not update
Fix the bug that the connection limit per task do not work
Crash Report can capture "Out of memory" error
20060727
Fix the bug that only few peers is connected
20060724
Fix the memory management bug that may cause memory leak
Fix the bug that the files selection download does not work
20060723
Fix a compile bug that may cause crash
20060722
Add option to auto stop after task finished
Fix UDP Tracker can not be connected
Fix HTTP Tracker redirect do not work
Beta version can only run on Windows 2000/XP
20060719
Add preview
Improve upload strategy.
Install to BitComet directory, can work with release version.
20060716
Fix the crash when click OK in the Setting Dialog.
20060713
Rewrite core code. Some functions are disabled temporarily.
