Browsing problems when BitComet is active
Hello,
I like BitComet and the features, especially the disk caching
technology is very usefull with my 16 MBit connection.
But there is a very annoying effect when BitComet is running.
I cannot surfe the web without permanent website loading
problems (cannot display the webpage).
I always have to press reload and wait and wait until the
page loads. Sometimes it works for some minutes without
these reloading action stuff but I defenitely notice that it
has something todo with BitComet.
Could it be that BitComet opens to much connection or
whatever (I dunno whats going on inside Bitcomet ^^)
so that my browsers (Firefox or IE7) always have problems
to get a page loaded when BC is running ?
I already tried to limit max parallel TCP/IP connections
to 5 instead of 10 (10 is maximum in XP-antispy) but
that did not really help.
My System :
  • Windows XP Prof SP2 (all updates)
  • 768 MB RAM
  • 1,9 GHz CPU
  • 16 MBit/s connection
  • Arcor WLAN Modem 200 (High-end Router)
  • Norton Internet Security 2004 (where Bitcomet has full internet connection rights)
  • Microsoft Windows Defender (additional anti-spyware software)
Thanks for any help on this, it’s really annoying =(
You probably need to set an upload cap.
Read through the Bitcomet Settings Help in my sig, I explain how to figure out your upload cap.
Oh and make sure your running the latest, bitcomet v0.68
I already have set the upload capacity to 50 kb/s which is half of my
available upload capacity. I just disabled DHT and now surfing the web
works again.
So should DHT be the reason for my browsing trouble ? :blink:
It seems so…
Yep, apparently your router isnt so high-end since it cant handle all the UDP traffic of the DHT Network.
see here
At least your router doesnt lock-up or reset like many others do.
Besides the suggestions in the link, see whether there is a setting in your router that affects UDP traffic. Maybe your router is scanning every single UDP packet which is causing the slowdown.
I have same problem about slow my internet. Is BitComet using too much UDP to broadcast ?
Is BitComet using all resources that possibility to connect the Source ?
I still get it to my assume. I wonder to know it.
Thank you.
