Dear bitcomet team!!! the browsing is so slow while downloading a file with bitcomet.
iam using bitcomet latest version and windows 7 32 bit along with ADSL modam.
My internet connection is BSNL broadband unlimited 256 kbps speed.
I tried with other Download manager like FDM, there is no problem atall.
But in the case of downloading speed, bitcomet is soopper.
So, hope this will solve in the next release.
Timy, the problem is with your settings not with bitcomet. If you allow bitcomet to have as much bandwidth as it can use, it will sometimes use all that is available and your browsing will suffer. We have prepared setup guides to help members with this, but the graphic (screenshots) part of the guides may not be of any help to you, so if you want to make it simple, the first thing I’d try is to run a speedtest and find what your max upload speed is, then adjust your global max upload speed in bitcomet to about 80% of your tested maximum, this will leave 20% in reserve and should help your browsing considerably.
A good website for testing your speed is speedtest.net
