yes but not the for the bt hub 64-C1
Hi razerindemix.
Is it the new white and shiny Bt Home Hub.
Like this One .. http://www2.bt.com/static/i/btretail/consu…ehub100x100.gif
If it is,Port forward.com don’t have it yet.
I got mine to work like this…
First u need a static ip address.You can find info on static IP’s at lots of places but http://www.portforward.com/default.htm is where i went.
Second …forwarding ports …
open hub manager
Click “Advanced” then “switch to another user”
You may have to enter name and password.
Usually it is “admin” and “admin”.
Then select “toolbox”
Then select “game and application sharing”
At the bottom of screen select “create a new game or application”
In the “NAME: NEW NAME” part put Bit Comet.
Then click “manual enrty of port maps”
Ok here u need to know Bit Comets listening port. You can find it at the bottom of here " bit comet/preferences/connection"
I have read that a port between 50,000 and 60,000 is best.
“protocol”=TCP,UDP,ANY…set to any.
“port range”=Bit Comets listening port (same number in the top and bottom box)
"trigger protocol"and “Trigger port” i left blank but u can read about them at http://www.portforward.com/default.htm.
Click “add” then click"Assign a game or application to a local network device"
Under “game or App” scroll down to Bit Comet" and select it.
Under "device "pick the pc that you want the ports forwarded to.
Click “add”.
Thats it…your done.
You need to configure any Software firewall you may have and remember to check windows firewall.
Good luck
And please let me know if this works for you.
