Bugs in Bitcomet 1.27
In the new Bitcomet 1.27 the Move Up and Move Down buttons are greyed out and dont work, also the new torrents which are opened do not open in a sequence but rather in the middle of the torrent list, sometimes up and sometimes down so the downloading queue is effected when Bitcomet is restarted.
Can someone from the development team please help. I am running Windows 7 Sp1 Ultimate edition.
You can click on any of the columns to sort the torrents in order with regards to the column. There are also many optional columns you can open to give you more ways to sort them.
as for the “move up” and “move down” buttons, my version 1.27 doesn’t have this (also using win7 ultimate). Can you provide a screenshot?
In addition to sorting by columns, you can click and drag the tasks to change the order.
Do remember that you must select a task before using the “move up” or “move down” buttons. I overlook that frequently.
Where are the “move up”/“move down” buttons in 1.27, I don’t have them on my installation at all?
View-Toolbar-Buttons - Move Up/down
Then you can see them
Hi gazdoc1
This is not a bug, and you can get the function working by the following steps:
The reason why the Moveup/down button greyed is that you currently make the task list in a certain order by name etc.
Notice the icon in the red frame(it may be in other column)
http://imgur.com/9Ml5x
or
http://imgur.com/BXtI0
For example, you click the name fisrt, and it turns out as the 1st picture
Then click name again, and it will appear the status which the 2nd picture shows
Finally click it again, and it will be like this
http://imgur.com/gmesG
Then you can find the move up/down button works well.
