any body know what casues these errors below? i tried doing a manual hash check, tried alcohol 52%, imgburn(does not support cue images at this time) and nero 7 ultra, not sure which version. nero usually does a good job for me but this torrrent is giving me problems. bad torrent maybe?
/post-3453-1162500916.jpg" rel=“”>
Here is the fix for most error in line 1 of cue sheet.
here is a fix for Error Reading Line 1 of blahblahblah.cue.
This is what the contents of a typical cue file looks like.
FILE “Saw II 2005 TS maVen kvcd Jamgood(TUS Release).bin” BINARY
TRACK 01 MODE2/2352
INDEX 01 00:00:00
TRACK 02 MODE2/2352
INDEX 00 00:04:00
INDEX 01 00:06:00
If you’re getting the error, what you want to do is rename the .bin file something simple like “movie” (without the quotes)
Then open the .cue file with Notepad/Wordpad and edit the first line to have the same name as the renamed bin file. So if you named your bin file movie you would edit the cue file to look like this.
FILE “movie.bin” BINARY
TRACK 01 MODE2/2352
INDEX 01 00:00:00
TRACK 02 MODE2/2352
INDEX 00 00:04:00
INDEX 01 00:06:00
Save and close the cue file and open with Nero. All good, burn away.
ps. just had another thought, these are two separate .bin/.cue disc images right?
yes. whenever i click on part one or part two cue file i get the same error. i just downloaded them at the same time in one torrent.
edit: thanks a million suspect. your fix worked like a charm! its burning as i type!
always glad to see a problem resolved
nice
help me http://forums.bitcomet.com/index.php?showtopic=4028
nice
Please don’t post requests to look at a different topic like this. If no one replys to your topic in 24 hours, you may send me a PM, but if you continue to do this, you will get an official warning, and possible account restrictions.
