i having problem with DHT (Green Light) still not connected? why? i cant download? help me pls
Follow our settings guide to get BitComet properly configured.
Now as to your reponce about DHT. Its not actually needed to download. It just an alternate way of finding peers using the same .torrent file as you via UDP. So make sure the port you’re using for BitComet allows TCP & UDP in your firewall.
hi, feeling free to tag my trouble / question herewith.
i am being able to download through bitcomet but for the last few days the speed has been less & i’m getting DHT NOT CONNECTED (green button at the bottom right has turned to no color). what could be the problem ? btw - i have tried utorrent & DHT is functional in there.
Did you just upgrade? Double check your firewall settings, make sure a port is open for TCP & UDP connections.
thanks for yr reply. firewall settings are ok, ports are open. besides, utorrent is able to connect to dht - i am just puzzled.
