Because if your settings are too sensitive for your system, then single-clicks can be interpreted by the system software as double-clicks when you don’t intend them to be – which is why you should have checked the setting.
You’d probably do better not to just dismiss anything you don’t understand. It discourages people from being willing to try to help you.
it’s ok, i’m not a tester, i’m not here to test for others, & i don’t have days to spend on it, i just got rid of cometbird, it was also causing stupid compatibility issues in terms of folder locations, as when i install quicktime lite 4.1 & the folder of firefox isn’t automatically found .. . so i had to move dlls manually & make sure i move the right ones. i’m done with cometbird, good continuation.
ps: you can delete this post if it didn’t make much sense to you, since i’m not going to read it anymore. life is short & i have better things to do. bye
Oh dear… the loss of such a contributive file-sharer in the P2P Community!! Whatever shall we silly, hard-working, altruistic and (gasp) non-paid members of said Community ever do without him?? :o
I know!! We’ll just continue (we don’t seem to have anything better to do) to think of, develop, create, test (over and over and over again), iron-out glitches and provide a completly free product, so that others - grateful, understanding, non self-centered beings that they are - can come and plod their way directly to “enlightenment”…
Alas… what a hard blow to our self-esteem, to be dismissed by a higher (albeit, somewhat amnesic) form of intelligence… <_<
(I think that I’m going to close this thread, in an attempt to prevent others from feeling erroneously “inferior”…)
