Changing downloading directory
I’m asking anyone with Knowledge of how can I change the saving directory of a downloaded file; here is the problem, I downloaded a .pdf file to open on an .exe file by mistake and now after the dowloading has been compleated I can’t open the file, How can I get it to open? Thanks for any help!
Preferences > Task. Select Default Download Path Here you can change the directory.
