Hello, I need to close running BitComet with a bat file. How to do it properly? Something tells me that it is too rude to use “taskkill /f /im BitComet.exe”
I use Win XP SP 3
BitComet ver 1.27 stable
I use Win XP SP 3
Maybe you could leave out the ‘/f’ and see if it then closes gracefully rather than forcefully.
Use the following commandline to exit bitcomet.
bitcomet.exe --exit
Here is a list of additional CL options
/monthly_08_2011/post-1287-13123298954264.jpg" rel=“”>
thanks, the --exit key definitely works
