Closing BitComet..
When I use BitComet, it causes webpages to load very-very slowly. It’s network/connections feature, I know… But when I close BitComet it usually takes up to a minute until all webpages start loading as usual. After closing it still sits in TaskManager for a while. If I don’t want to wait, I need to kill the process. Why cannot it close instantly? Maybe the reason is that it’s disconnects from all peers/trackers etc.. ?
Regards
Paul
stop all downloads first and it should be ok
I had the same problem with some streaming tv program, I just needed to stop the video and close it after
Yes this is actually the same with most P2P applications. It’s best to stop the torrents, then exit the applications.
Out of curiousity, what was the file size of the torrent download?
i have a problem in bitcomet 0.66 i’ve been using 0.66 for a couple of months and 2 hours earlier there went an error every 5~15 mins my bitcomet crashes there will be a window and it tells if you “Send” or
“Don’t Send” can someone help me fix this problem thanks in advance
:slight_smile:
RTF(ine)M
