Lets say a task has got from 0% to 55% while BitComet has been running, then I shut down the computer. When I open BitComet again, the task says it’s at 0%. However, when I start the task again it suddenly jumps to 55% which is where it was.
It only started this in 0.69 but never happened in 0.68.
It only happens if BitComet is closed by Windows due to a shut down operation. If I close the program myself, it saves the % download completion value.
Hope that helps.
-Stu
