Hi ive been using bit comet for a couple of years now and since i have rebooted my windows i seem to have developed a qwerk with bit comet.
I can’t seem to log into the lower window pane with my comet i.d although both the user name and password are correct. Im running windows 7 64 bit and bit comet 1.29. My i.d is rapter97@hotmail.com. Any ideas any 1?
Your comet id and email address are two separate things, I suspect you’re trying to use the wrong login. Try going to cometID.com and logging in. If your name and password are correct, you should have no problem.
