Hi,I’ve just started using Cometbird, what a pleasure it is in every way! I have a query,if anyone can help, can you please explain in the most simple terms? I am not at all technical.I’m on dial-up and I use the truly excellent DownloadAcceleratorPlus, thing is how do I get Comet bird to recognise and use it? Thanks
I’m not certain this will work, but there is a firefox extension called “flashgot”. This allows you to direct any download to a choice of download managers. BitComet has a version of flashgot that installs to allow you to filter what downloads go to bitcomet, but if you install the regular version of flashgot, you should be able to select other download managers. However I don’t know for sure if yours is supported by flashgot.
I hope this helps
