Hi guys … I have downloaded the latest versione (0.79).
The CometZone login doesn’t work!
That’s correct, and its purpose is unclear. You should downgrade to a stable version and stick with it until another stable version is released.
i try newest bitcomet 0.8 and the result was amazing. auto max download and its more stable than 0.70. u guys should see it 4 urself… ![]()
Unfortunately, that only means it’s stable on your particular system. We have a lot of reports that it’s not on others.
