Hello everyone;
I’m new here and I have registered because I have two major problems that happen every time I use a torrent client. I was wondering if anyone could tell me why this is happening, and help me figure out how to make it stop. I’ll try to give as much information as I can.
First, I will point out that this only started happening after I moved, back in October, and had to change my internet company. I am now using a wireless wi-fi device to connect to the internet (photo of the device:)
So, as I said, two problems. The first, ( also the least serious out of the two): whenever I use a torrent client, (I tried many), my internet browser stops functioning. As a result, I can not download torrents and surf the internet at the same time, because if anything is downloading, all I can get from my browser are “not found” error pages. This is not a problem with the connection; the torrents are downloading normally and at a decent speed . But whether it’s Opera, Firefox, Internet Explorer, or any other browser, it will simply act as if I wasn’t connected to the internet. The only way to make it work again is to restart the computer. Very annoying!
Note that, on occasion, it continues to work as normal. I have no idea why it *usually *stops working but not *always. *And, for some reason, Internet Explorer doesn’t seem to fail as much as the others.
If that was the only problem, I could live with it. Problem number 2, however, is more serious.
Whenever I use a torrent client, after a while, the computer will freeze completely. The screen becomes completely frozen, and even the mouse cursor will not move. This happens no matter what I’m doing, whether I’m watching a video, playing a game, etc. If there’s any sound playing at the moment when it freezes, the sound will also get stuck; for example, “Luke, I am your fatheEEEEEEEEEEEEEEEEEE”.
The only way for it to get un-stuck is for me to manually switch off the computer and restart it. Also note: this happens even if I quit using the torrent client before the freeze happens. So, for example, I’ll use bitcomet, download something for a while, switch off bitcomet, and still, the computer gets stuck after a while (unless I restart before it happens).
At first, I thought maybe something was wrong with Bitcomet (latest version), but then I tried Tixati and Deluge, and they both had the same problem.
Another piece of info: I usually turn on Peer Block when I’m downloading stuff, but the problems happen regardless of whether I use Peer Block or not. I’ve also tried to use PB by itself without downloading any torrents, and none of the problems occured. So I definitely know PB isn’t to blame.
As protection, I use Avira and Comodo, but I think this is completely irrelevant, because I’ve been using them for a long time, but the problems only started after changing my internet company.
As a result of those issues, I can’t leave something to download while I’m out of the house, because the computer will be frozen for sure when I get back, usually before the download has had the time to make any real progress.
So basically that’s it. Any ideas?
Thanks.
