connecting?
I’m very new to the whole BitComet program, and i just started to download a torrent using the website podtropolis.com. The problem now is i get the torrent into cache, but the program says under the status category that its connecting. This has been like this for a while now, and i dont know wats going on. can anyone help me?
we need more information, version of bitcomet, some details about your internet connection, how many seeds/peers etc.
its BitComet 0.77 and a fast DSL connection. Seeds and peers im not sure of and again like i said im new at BitComet so its all a bunch of nonesense to me… would logging in help to get the connection working?
Logging into bit comet passport has no effect on running torrents. The new feature is still in beta testing, and won’t be available for a while yet.
Please have a look in our guides section, for a post by soraiya “new to bit comet” and read through.
I will also add that since you are new, I would recommend you use our latest stable version .70.
The new client still has some bugs in it.
o ok well hey thanx alot, im thinking it should probably work then if theres some bugs still going through it
