console games someone please help
Here is my dilema, I already downloaded and burned several games to disc now the console PS2 to be exact is asking for a format disc what is this all about. and what do I need to play these games and how do I get it?
It is asking for a disk that is in the correct format. It’s telling you that it does not recognize that disk as a valid PS2 disk. You will need to modify your PS2 in order to play downloaded games, which you can find more information about elsewhere – this has nothing at all to do with bittorrent.
One place to start is here: http://www.swapmagic3.com/
Also, you should be carful when burning console games because a lot of people don’t back them up properly. Use Alcohol (Slysoft CloneCD also works) to make the copy with all the error correction options turned off. If it gives you a message about an error just hit “ignore” and keep going.
For burning use Alcohol 120, CloneCD, or Imgburn. Do not use nero. You have some reading to do if you’'re looking to back up PS2 games.
