Contiues inbounding
Why my computer is contiues downloading things after I exit the BitComet?
The firewall state that there are lots of users inbounding my computer but it does not happened when I using BitComet. It just happen after I exit BitComet.
When you download with bittorrent, you connect to many other clients in the swarm, who are sending data to you. When you stop, it takes time for them to all get the word that you’re no longer there. It’s normal, nothing to worry about.
However it contiues for an hour…
If you don’t want this to happen then you should stop your .torrents and let them sit for at least a minute before removing them or closeing BitComet. So the signal will be sent out that its not there anymore.
