Couldn't succeed with Port Forwarding
Hello everyone, I’ve tried already reading all kinds of posts and guides all around the web but I couldn’t get my port opened lol.
I’ve followed a guide in portforward.com, still my port is closed.
1) BitComet 1.40
2) I’m not sure what kind of internet connection I have.
3) Router: Dlink DSL-6850u, a VDSL modem + router given by Israeli telecom provider Bezeq.
5) Windows 10 64Bit, Eset Smart Security 9.
I tried forwarding port 27225, made exceptions and rules in ESS9, turning on uPnP in my router and enabling it in ESS9 and Windows.
I have a local static IP, but my remote IP is changing, is that okay?
BitComet statistics:
TCP Connections: Established: 0 [MAX:Unlimited] / Half-Open: 14 [MAX:200]
LAN IP: 10.0.0.5
WAN IP: 109.65.XX.XX
Listen Port of TCP: 27225 (Blocked by Firewall/Router)
Listen Port of UDP: 27225 (Opened in Firewall/Router)
Windows Firewall: Added [TCP added, UDP added]
UPnP NAT port mapping: Failed [Dlink (http://www.dlink.com/)]
Disk Boost Service: Running
Overall Download Rate: 0 kB/s [MAX:Unlimited] Max Connection Limits: 50 per task
Overall Upload Rate: 0 kB/s [MAX:Unlimited] (for not downloading) LT Seeding: 0 kB/s [MAX:Unlimited] All BT Upload Slots: 0
Memory Usage: Working Set: 85.42 MB, Commit Size: 88.75 MB
Free Memory: Phys: 13.23 GB (Min to keep: 50 MB), Pagefile: 15 GB, Virtual: 131,039 GB
Disk Cache Size: 0 B (Min: 6 MB, Max: 50 MB)
Disk Read Statistics: Request: 0 (freq: 0.0/s), Actual Disk Read: 0 (freq: 0.0/s), Hit Ratio: 0.0%
Disk Write Statistics: Request: 0 (freq: 0.0/s), Actual Disk Write: 0 (freq: 0.0/s), Hit Ratio: 0.0%
UPnP Test Program v1.16 Copyright Mark Gillespie 2010:
TEST 1 - Operating System Support - PASSED
TEST 2 - SSDP Service Running Check - FAILED
TEST 3 - SSDP Service Automatic Check - FAILED
TEST 4 - UPnPHost Service Running Check - FAILED
TEST 5 - UPnPHost Service Automatic Check - FAILED
TEST 6 - UPnP Framework Firewall Exception Check - PASSED
TEST 7 - Adapter #0 - 10.0.0.5 - FAILED
TEST 8 - Get External IP Address - FAILED
canyouseeme.org:
Error: I could not see your service on 109.65.XX.XX on port (27225)
Reason: Connection timed out
UPnP
UPnP mapping does not work in all cases; you might need to forward your port manually.
Follow this tutorial to forward your port on your router: https://www.youtube…h?v=HGPrN62QTZw – if you say you already have a static IP, you can skip some steps: https://youtu.be/HGPrN62QTZw?t=190
PS: Make sure you forward for both TCP and UDP. Also, restart BitComet to validate the new settings.
Internet Connection
Please do some research, and tell us what kind of internet connection you have. It is crucial, as this might be a reason for your ports to be able to be forwarded or not.
VDLS Modem
Hmm… Modem… According to this article, your modem is incorporated within your router, is that correct?
The easiest way of doing this is to call your ISP and ask them directly…they should be able to tell you if you have (for example) an ADSL connection, or a 3G/4G WiFi connection, fiber optic… :slight_smile:
UPnP UPnP mapping does not work in all cases; you might need to forward your port manually. Follow this tutorial to forward your port on your router: https://www.youtube…h?v=HGPrN62QTZw – if you say you already have a static IP, you can skip some steps: https://youtu.be/HGPrN62QTZw?t=190 PS: Make sure you forward for both TCP and UDP. Also, restart BitComet to validate the new settings. Internet Connection Please do some research, and tell us what kind of internet connection you have. It is crucial, as this might be a reason for your ports to be able to be forwarded or not. VDLS Modem Hmm… Modem… According to this article, your modem is incorporated within your router, is that correct?
Thank you very much, this guide helped me :slight_smile:
All I missed was ‘Static IP Lease’ or something like that.
You’re welcome, as usual :slight_smile:
