hi there ppli have down loaded paint shop pro 7 with a crack but i dont know hat i have to do with can u please help many thanks pitstop
I downloaded this, but quite a long time ago so it probably isnt from the same source.
If the crack you are talking about is an .exe file, its probably a case of installing the software then going into its directory and replacing the exe file there with the cracked version.
Most downloads have a readme.txt that tell you exactly what needs to be done, so your best bet is starting there.
Please noteā¦
Our forum rules do not allow us to assist members in disabling activation, registration, or bypassing any security built into anything you may have used our porgram to download.
Topic closed
