Today I installed Cisco Systems VPN Client. Ever since this installation Windows start crashing after few minute BitComet is running. However if BitComet not running the Windows running fine. I have tried to uninstall Cisco Systems VPN Client and Windows doesn’t crashes.
How to I keep Cisco Systems VPN Client and at the same time use BitComet?
It would seem to me that there is a conflict in resources between the two clients. I have no direct knowledge concerning this, nor could I diagnose this in a forum post, but unless we can determine that this is a bit comet bug, I’m going to move this to tech support section. Hopefully one of our staff/members will have a suggestion for you.
In the meantime, I would visit ciscos web site, and check if this has been reported there.
moved to tech support
Appreciate for the update TUS.
How about others? Does anyone have experience the same? Please shed some light. Thanks.
Is there anyone that well verse with this? Is that Cisco VPN Client overwriting the TCP/IP connection limits which cause the system freeze? Appreciate if anyone cans shed some light to overcome this incident.
