It might be that your dvd player has issues playing vcd discs.
Here is a good web site for info on its compatibility with types of discs…
http://www.videohelp.com/
Its also very possible that the manufactorer has a firmware update to resolve that issue.
Your nero 6.6.0.18 will burn our kvcd quite well, with either burning rom, or nero express. I will post a guide, just use the slowest speed, and shut down ALL programs during burn. I also recommend you power off modem, or unplug your computer from your network if you are having burn issues.
You might also want to try the disc on a friends dvd player, see if it plays well, so you know which route to take to resolve this issue.
As I mentioned before, you can try to play this disc in windows media player, or any media player if it burnt proper, but it will not give good quality playing on pc.
Here is a guide for burning with nero…
First step is to update your Nero till the last version on Nero 6 or Nero 7.2 and above
Click Cancel
Now click the file tab then prefrences
Click the expert features tab then tick “Enable Disc-at-once CD Overburning” and change the time to 84 mins. Also tick “Enable generation of short lead out” if you have that option
Now onto burning bin/cue
Locate the folder where your downloaded KVCD is then right click with your mouse on the cue file and chose “Open With”
Click the browse button and go to the Ahead folder in your program files
Find your Nero.exe and then click “open” on it
All you have to do after that is pick your burn speed, wasnt that hard now was it winking.gif
Also in future when your right click on a cue file the option should be there to open it with Nero so you dont have to go through all that painfully long process again tongue.gif
