Hi i downloaded a game and it is a daa file, i am having trouble installing it, can i have a bit of help please on how to mount, it on to a disc. many thanks B)
your file.daa (direct access archive) is a disc image made with PowerISO.
Google can find their website where you can download a trial version, or any good torrent site should have have it as well.
You can then mount it in a virtual cdrom drive, burn it to disc, or convert it to an .iso.
Some other programs will also convert .daa also.
I have done what u said and when i go to ply it says wrong disc inserted please help
Since this topic is in no way related to bit comet, I’m moving it to the approaite section.
As for your game, I still don’t know what game you have, or how you installed it, but if you installed from a virtual cdrom drive, then you prob need a no-cdrom crack.
These usually come with the torrent, so look for a folder called crack, patch or something simular. Also look for a file.nfo, which should have instructions. You can open .nfo files in notepad.
