Ddos attack!?
I was using Kaspersky Anti-hacker, P2P was BitComet 0.6X. Some time it reported Ddos attack and shut down the connection, then the connection remain by AH software. Delay time is depending on setting.
If I shut down the AH, the connection will be disabled when Ddos attack. Needed to restart the computer to remain the connection.
Other latest AV and internet security software is not notice it happen, Just stop DL & UL.
It only experienced with BitComet!
How to prevent it…Is the preferece setting make it happen???
