Adresa LAN o poti gasi si in BitComet, tabul “Statistics” de jos, acolo ai o linie "LAN IP:192.168.123.". Ia al 4-lea set de pana la 3 numere din adresa () si pune-l unde am incercuit eu cu rosu in imaginea de mai sus.
It’s the IP column from the screenshot given by you:
You can find your LAN ip in BitComet, in the “Statistics” lower tab, there you can find the line "LAN IP:192.168.123.". Take the fourth set of up to 3 digits () and put it in the encircled box shown in the image above.
