Desirable features
Hi all,
I am an ex-Azureus user…and moved over for reasons stated in a previous post (faster, smaller footprint, less cpu, less mem, etc)…but there are several features which I miss quite a lot.
Here’s a couple of features I would like to see, if possible:
  1. Seperate folders for downloads (i.e. incomplete/incoming and a completed folder). This would be great and my most desired feature. All incoming files go to one folder and are moved to another folder when completed/re-hashed.
  2. Up/Down speed readouts - so I can see at a glance how much bandwidth is being used up and down, plus the effect of any limits I have applied.
  3. Seeder list / better health readout - Azureus gives a graphic display of the number of users seeding a COMPLETE file - just a simple check to see whether this is over 1.0 or not - if it isn’t then you know you might have a hard time getting it. If it is under 1.0 (i.e. 0.99) then you know that there isn’t 1 complete copy in existence at that precise time.
Thanks, and a great client so far by the way! :slight_smile:
Finally, the searches aren’t much use- I say get rid of the web/IE integration all together.
Cheers.
Er, we have recorded these features.You know that we have lots of work to do. Maybe we will realize them in future. Thanks.
Suggestion one is great. I fully support it.
