i have read through the configeration steps and have tried multiple combinations of things.
but 0.70 still reads as DHT not connected.
i am connected via a router and cannot download anything at this moment in time. please help
signed
Eman
signed
Eman
First, in your software firewall did you configure it to allow BitComet full incoming & out going connections aka server access? Did you set it to allow DHT & UDP connecionts on that port? What software firewall are you running?
Now as for your router, do is have a built in firewall?
i have indeed allowed te prorgra in norton internet security 2005 and am unsure if the routuer does its a d-link-524 but now that i am concidering it that may be the problem. but as for the port & DHT UPD i am unsure of how to set that up effectively. ( in norton).
as for your dlink router, dlink refers to forwarding your ports as “virtual server”.
You will need to make a virtual server for each computer that is running bit comet.
It’s also important to set a static ip address in windows (or you may need to update your virtual server each time you reboot)
As for the members who upgraded to newer versions of bit comet, I suggest you delete your firewall rules concerning bit comet, and make a new one, as your firewall may be allowing your old bit comet, but not recognising the new one.
To the person with the Dlink 524
Make sure in the Advanced options that Gaming Mode is enabled
