dht network disabled in task properties
i am getting alot of torrents that are coming up with the above mentioned topic what can i do HELP
Are you asking how to enable dht network? There are three ways to disable it, in your global settings (all tasks), your specific task settings (one task only) or while making the torrent it can be disabled for all users. Private torrents always have dht disabled.
thank you, you answered the question they must be privated cause i cant download them
:lol: … he really GOT it !
found out a little more about how to fix my problem i went into the advanced sttings and found that most of the boxes were not checked that is why it was disabled
This is what I explained, dht can be disabled in your global settings, task settings or disabled when authoring the torrent.
thank you
** **The UnUsual Suspect
OK… NOW he’s got it!!!.. :smiley:
TUUS, perhaps you’ve got to explain things a wee bit S-L-O-W-E-R… :stuck_out_tongue:
Al least, he was courteous enough to thank you (a most welcomed difference from many others) :slight_smile:
