my cliant says at the bottom DHT not conected WHAT is a DHT and how do i conect it
DHT (distributed hash table)
http://en.wikipedia.org/wiki/Distributed_hash_table
a secondary method of tracking torrent
This is only used if the torrents tracker permits it, and you, and at least one other peer enable it.
I have the exact same problem. but I haven’t found an answer anywhere… and I don’t know how to connect it..
DHT will NOT connect unless it is needed
This technology is only a backup method of tracking the torrent
ic… i still can’t download anything and I don’t think it’s my firewall .
Its either your router, firewall, or connection(ISP). Usually it is your firewall. What firewall are yo using? Does it allow BC to send/receive UDP connections?
