Disapprearing peers and arrows
I have noticed issues with the .68 version. (winXP pro OS)
  1. Some torrents after connecting the peers are disappearing, the UL/DL progress without any issues though.
  2. This is a bit annoying, on trying to set individual task speeds (properties → Advanced), the up and down arrows(incremental buttons) of the minimum upload/download to keep options are going off. I have to increase/decrease the speed only with keyboard arrows then.
Is that only me or others have same issues (first one can be nelected :wink: )
Those are known bugs. Don’t worry about the peers, it doesn’t actually affect anything. As for the arrows, click on the numbers and use the up & down arrow buttons on your keyboard until that bug gets fixed.
