I have been downloading a movie, who had hundreds of seeds. But when (yesterday) it reaches 99,9% it stopped downloading the rest of the file. And reamins only 256KB to finish. If i could be more specific, i could tell you that its still downloading, but all of the data is being ignored, I mean, discarded. Anything different happens to explain that.
I began another download to check, and it’s going well.
I dont know if it could be a bug.
Does it has any relation with the software? Or am I really f***** up?
Stop the .torrent and perform a hash check. Then make sure you are actually connected to seeds, because you may have found yourself a fake .torrent or you have a common download problem with it stoping at 99.9%.
it could possibily no1 else has the complete file either, so hense no1 can give u the remaining 0.1%. dunoo just giving my 2 cents
Yes, that’s most likely the case since the person who created the torrent may have modified a file (probably a text file) after creating the .torrent file.
Check the filelist to see of all critical files are complete – if they are and some insignificant file is incomplete, then everything should be fine.
I may be a newcomer but I think I have a related problem.
I’m recently downloading a torrent of 1 file, a video file actually (170MB) that is very popular (3000+health) with lots of seeders (and no more hints as to what it is )
I began a couple of days ago and had to restart because of the 99% limit (i had already reached 700MB of rubbish )
When I restarted I noticed that this torrent, compared to others I had downloaded already, was incredibly fast, but the catch was that 50% of the data was rubbish. Right now (1:45am Colombian time 10-08-06) I’m still 50MBs short and nowhere near completion with 480MBs of rubbish :blink:
I know it’s not a seeding problem because 35 out of 40 of my peers are genuine seeders (fully downloaded) and the manual hash check says it’s all A-okay.
Every 15 minutes or so 256kbs are successfully downloaded but I fear that I’ll just reach the 99% limit and end up with who knows how many gigs of cr@p
If anyone could explain to me what is the discarded rubbish, how it’s generated and if I have a problem with the client or if there is any solution to this problem it’d be very grateful
/----------EDIT-----------/
Sorry, I forgot to read the updated faq and if my problem is what is described in there that means I’m screwed
