Hi,I just upgraded Bitcomet from 1.25 to 1.26 and the first thing i noticed that’s the review of Disk space when opening torrent ~
I found its really hard to manage and i think the previous is better ( when bitcomet reviews free disk space and file size in 1.25 version ) Can we change it back ?
I won’t argue if this way is better than the previous one or not (personally, I too, kind of liked it better before but it may be just because I was used to it for so long).
I just wanted to let you know that the file size for each task is still present on the page; you can find it now in the brackets after the “Select all” check-box, in the lower left corner.
