does it help
i have read atopic about how to fasten the speed of downloading of bitcomet.. and it says there that disabling ip filter will help..does it really can help? is there any risk if you disable it? :unsure:
I don’t think that disabling of ipfilter.dat use will improve download speeds (unless you have half of Internet there :slight_smile: ) as this file is empty when you install BitComet (hence no one is blocked and no time is required to check all peers you’re connected to). Could you give me a link to this discussion (PM or here)?
