Hey guys, im new to bitcomet as ive only just got into torrents and tried to use azureus. Ive got telstra cable which is fairly fast and yet i cant download very fast.
Ive switched to bitcomet as i could only get 3-7kbps download which is pretty crappy. Now i use bitcomet and can only get max of 10…
Im hoping someone here can help me configure the stuff to work well and give me speeds i deserve.
If you need any of my info, here it is.
port used: 50050
Router: Belkin F5D7230-4
Firewall: Sygate Pro(configured to allow access..)
Any help would be awesome:D
Thanks,
Kenny
You don’t need to give us your IP and you probably shouldn’t.
Now we’ll start with BC first, use this settings guide for BC: http://forums.bitcomet.com/index.php?showtopic=533
Just a warning, don’t mess with your “max half-open TCP connections,” it causes more problems and trouble then its worth.
Your routers turn now, everything you wanted to know about your router. A warning about Belkin routers, they’re great but you need to use IE when logging into them. They have a little error in their code that Firefox is allergic to.
As for your firewall, make sure the rule for Bitcomet allows TCP & UDP connections. B)
