Download file (index.htm) from inside.bitcomet.com
Hello
Every time I start my Bitcomet I am asked if I want to download a file: index.htm, from inside.bitcomet.com - what is this, and how do I get rid of it? It´s kind of annoying… :confused:
This is what I see…in Swedish, but I hope you can tell :)/monthly_07_2013/post-127612-0-08280100-1373893187.png" rel=“”>
I believe this is data that bitcomet uses to display your CometID info, but I’m not sure why Chrome is grabbing it, it’s normally handled by Internet Explorer which bitcomet uses to display internal web content.
Does your cometID pane display properly?
Also, as a test try disabling everything in Options>Service and see if the prompt stops.
When I opened Bitcomet again, I noticed that the window (pane?) down to the right (Start page) is empty…
Tried to disable the checkboxes in Options>Service but it did not work.
Thanks for your answer by the way :slight_smile:
Your post is difficult to understand, what does “window (pane?) down to the right (Start page)” mean. It looks to me like you’re describing three different things.
You tried to disable the checkboxes but it didn’t work… you couldn’t disable the options???
If you can’t describe something so that we can understand you, take a screenshot and post it.
I would try to re-install BitComet, to see if it doesn’t fix this during the re-installation process.
